245/45/19 front tires 275/40/19 rear with 20 mm spacers all around
safi
Hello guys i have 2023 g70 sp rwd stock wheels planning on putting 245/45/19 front tires 275/40/19 rear with 20 mm spacers all around will this fit no rubing ? Will it sit flush with fenders ? With Stock ride height
The reason is for bad roads and protection from potholes.
That's a huge spacer, and will have a negative impact on the vehicle's steering and wheel bearing life. You'll also need longer bolts (unless they're included with the spacer).
If you're worried about pot holes and bad roads, going with lower profile tires isn't recommended.
Yes bolts included just want to know if they fit without rubbing and these are taller sidewall than stock
I am going with spacer because i know wider and taller tires will rub on the inside and anything larger than 5 mm spacer will need studs replaced and only 20mm plus come with studs includdes in the spacer
I'd only run a spacer in the rear, don't want to veer too far off the factory +34 front offset, it will negatively affect steering response.
