3.8 AWD automatic transmission adaptation
smirn0ff
Genesis owner
Bulgaria
Hi Guys,
is there a procedure for recalibration of the automatic transmission?
Did someone knows?
Hi Guys,
Did someone knows?
Hello, I have the same car as you. Does your genny tend to jump a little when changing gears like from 2nd to 3rd? Because I have this issue and it is so irritating.
yes, from time to time, when you drive with very little throttle, it feels
Adaptation should be done after you erase the transmission adaptive values using an advanced OBD scanner. Then you can run the adaptation special function which is done when the ATF temp is in a certain range and throttle is less than 25% and then you drive from 1st gear to the 8th and down to a stop, repeat 5 times. Then you park and move the shifter between R and N 5 times and then N to D 5 times with 5 seconds pause in each position.
On another note, the jerk you feel from 2nd to 3rd or sometimes from 4th to 5th gear is due to an issue with the Transmission oil pump in my opinion and based on my research.
Good luck.
H.
yes maybe is something mechanical, but mine transmission had fluid change on every 90000km, so must not be.
I had issues with the throttle valve because of fail when dealer try to clean it, after that needs replace. with the failed throttle I made some 1000-2000km until I understand it is bad.After that until waiting the replacement I have done 200-300km and after that the fuel pump controller failed. Also needed replacement
