3.8 Coolant Type?
Joefuze
Anonymous dating without prejudice
Usa
Anyone know what coolant the 3.8 takes. Need to add a little and don't want to screw anything up.
In case anyone is interested.... after some research, the manual states an ethylene-glycol based coolant.
I would strongly suggest you get the OEM coolant from a Hyundai dealer. One gallon costs about $20 and will last a long time if you just need to occasionally add a little bit, since you mix it with 50% distilled water. Asian cars typically use a different formula than most other cars, and although there are aftermarket ones available for Asian cars, they are usually not any cheaper than the Hyundai OEM one. Also, using the OEM coolant will keep the color the same.
