simplicityinsound
- Mar 25, 2012
hey guys,
so i noticed something rather bizarre today while testing this car.
2012 genesis sedan 4.6.
the car has been in my garage being worked on, only stated and idled a few minutes a day to keep the battery topped off.
today i acutally went and took it for a drive around the block.
so just to test voltage, i took out my multimeter and noticed that while idling, the car is only charging at 13.2-13.3 volts.
this is lower than any other car i have tested.
so i let it idle bit longer and eventually, when i checked on it again in about 20 mins, it was charging at normal voltage of 13.9-14.0 (this with the stereo system idling so drawing a lil voltage).
so i wanna confirm what other people are seeing? i assume this is a computer controlled alternator, but what i dont quite understand is why on a somewhat depleted battery, it will only charge 13.2-13.3 for the first oh...15 mins or so (5 mins of idling 10 minute drive) and then bump up to normal voltage later. most cars i have measured, even with computer controlled alternators, seem to charge at 13.8-9 even on start on, regardless.
so i wanna see what you guys have to say and determine if its something wrong with this brand new aftermarket battery (i have had that happen) or if this is something totally normal with this car?
thanks!
Bing
thanks!
Bing
