5.0 Fuel Filter Replacement
SixFootSix
California
How difficult is it to remove and replace the fuel filter on the 2012 5.0 sedan?
Mine has not been replaced, and I just turned 94k miles.
If someone has the process steps from the mechanic book, I may try it myself.
I just finished the remove, rebuild, and reinstall of the fuel pump/fuel filter combination unit. Ever after removing the fuel pump fuse and running no the car until it died, the line still had 1/2 cup of pressurized gas.
Then removal from the tank on a 2012 is easy. The disassembly of the unit to replace the filter is a little difficult. Mine had 94k miles on it and was visibly dirty. I did not purchase or install a new screen, instead I just cleaned it.
Total work time was 90 minutes.
Nice job! Where in California are you located?
