6 cylinder vs 8 cylinder brakes
Genentec
can someone clarify how many pot piston caliper the 8 cyl has vs the 6 cylinder.
8 cylinder is 4 piston I believe. not sure if there is any difference from the v6.
Both the V6 and V8 get 4 piston front, single piston rear.
The front ventilated disk is 13.6 inches on the V6 vs. 14.2 on the V8.
Rear disk is the same on both.
Ditto 2012. Brembo fronts, I believe, and floating caliper rears.
No Genesis sedan ever had Brembos from the factory. ;)
Is there a stopping distance difference between the V6 and V8?
the brakes are pretty good on the 5.0, sure seems a lot bigger than 4 piston calipers. the front calipers are huge.
