87 Octane Dyno
Slip_Angle
920
93
Canada
I'm curious if anyone's seen a dyno chart running 87 octane in the 3.3T. I've run 91 ever since I bought the car but since winter is here now, I'm trying out 87. I've heard (unofficially) that there is a minor power drop but nothing material. Butt dyno says no change whatsoever.
NLJ
1,073
Vancouver
Shouldn’t effect your torque but there will be a drop in peak HP.
NLJ
1,073
Vancouver
So it would change the shape of the torque curve, to a lower RPM?
Not entirely sure. Just making an educated guess based on the Mazda CX-9 which has the same torque throughout and only an increase in HP with premium.
Also HP is made at higher rpm anyway and that is where you see the effect of power reduced.
I used regular a few times last winter and didn't notice much difference but I was also driving in Eco.
Husky
673
93
I was just wondering, since hp=torque x rpm / 5252. (So hp will always equal torque at 5252 rpm - neat!)
The only way to change hp without changing torque is to change the rpm that the torque occurs at. I guess this could be octane dependent if the ECU adjusts valve timing or ignition timing accordingly.
Pedal Commander
