A/C compressor
Bski224
Hey guys, It seems my A/C compressor is constantly running even with air off clutch is always engaged. Air doesn't blow cold either. Any ideas?? I heard this may happen if low on R134
Yep r134 is low and that means a leak in the system. Most leaks will be the seals at the compressor shaft which will require replacing the AC compressor.
Excellent thanks, have an apt Saturday with dealer. Hope it's covered under warranty. I'm the 2nd owner and still have a year left on the 5 yr warranty.
You should be In Like Flint.
