A Couple of Mod Questions...
Don88
Vancouver WA U.S.
Genesis G80 Ultimate
Regarding a 2018 G80 Ultimate:
1. Has anyone changed out the door sills to led back lite units? Do you have instructions to share?
2. Has anyone added a third brake light flasher unit? Do you have instructions to share? Where is access to the wires that feed the third light? I'm considering the type that has a accelerometer builtin. Slow flash for normal stops; a bit faster flash for quick stops and a rapid flash for emergency stops.
Many thanks,
Don
I'm interested in knowing the wire routing thru the Body for the brake light & upper brake light wiring along with wire colors... Need to figure out where to tap into the upper brake light wiring....
