A Little Help Please"
WowCool
Nr Jamestown CA
Hi All,
the "G" sure is a gr8 chariot"
2?'s -> (1) When the radio is On and Ignition is Off the Battery Drain Alert is like' every few seconds! is this correct & does the "G" auto Turn the radio Off after say 30minutes?
(2) Locking the vehicle produces a ""Cheep"" no Horn.. Can the Horn be programmed to Sound when locking the vehicle?
HappiMotoring
Your neighbors will love the cheep, instead of the horn. Since the turn signal lights also flash when you lock the car, aren't two alerts enough?
Yes, the "nag" message is displayed every few minutes. I've sat in my car for as long as 30 minutes with the radio playing and it did not shut off automatically. Perhaps if the doors are locked and the key fob is not around it might but I have not tested that.
What entertainment package is in your car? My 2009 V8 sedan with the Tech package will let the stereo run for an hour (with the engine OFF) before it automatically shuts down to preserve the battery. The nag screen pops up every few minutes. I use the options menu to blank the screen... nag still displays but otherwise it stays off, hopefully reducing the battery drain a little bit.
mike c.
Many Tx
Again many Tx for all your help & advice.
Lenni with a "Genny"" :cool:
