ABS, EPB and ESC warning lights
Ghettosled
Lakewood, Ohio
A couple of weeks ago, had the ABS, EPB, ESC and auto hold lights come on. After restarting, they would go out. Now they come on about every day but only when I go on the highway. Was thinking about bringing it to the dealer, but decided to try scanning it myself. I purchased a Zurich 13s scanner from Harbor Freight, and it pulled the ABS error code for a rear speed sensor. I will check it out this weekend. Maybe the scanner will be worth the minor investment.
I assume the sensor is going bad, so I went to pop it out and the thing is rusted/corroded in place. Now that it’s coming off in pieces, a new sensor has been ordered. 9A58E563-26DE-4A39-8B77-90934CB624F1.webp
After drilling the broken bolt, breaking the EZ out extractor in said hole, and the sensor breaking flush, it’s all finally back together.
Best of all, all the lights are off on the dash.
I have a 2013 and I had the same problem. I ended up replacing the left front wheel hub. This fixed the problem.
