Ac compressor
californiabear3
if your AC compressor goes out Does that cause the rest of your car to start overheating?
Good prices on AC compressor?
Should have no effect on the engine cooling system.
Car has been smoking randomly when taking long drives. Check engine light came on it was the coolent temp sensor. Took it off cleaned it as it is a special order and the check engine light went off. After 2 months it's back Again not sure if it's the same code I'm getting it checked tomorrow
Welcome. Moving this into our first generation Genesis Sedan forum...
Engine overheating will turn off compressor.
Fix the overheating or temp sensor first.
I agree with this. If your engine keeps overheating, you'll have much bigger problems than just an A/C compressor to worry about.
