Adding an amp and sub box to 2015 Sedan 3.8 w/ 14 Spkr Lexicon
wchavisiii
I’ve checked here in the forum and found where the guy provides a diagram and says pins 13 and 26 are for sub 1 and use those.
My connector 1 (white connector), the only has 22 pins and a pos and neg pin. The gray less wires/pins.
Can anyone give me guidance on what wires to tap off to provide to my LOC?C21AFDD1-183E-4F09-8AED-0BF278B220A4.jpeg
Can anyone give me guidance on what wires to tap off to provide to my LOC?View attachment 30400
Not sure if you've found the answer but I used the grey connector. As the are in the photo, you want the pair in the 2nd row from the top.
Hello yes I figured it out. Thanks for the reply!
These?
What you connect the loc to ? What color wire ? I have a setup but I’m pulling voices from the subs
What pair ??? Helpppp
What you tap into ???
What wires you tap ? Color ?
