Adding under the seat subwoofers to a 2019 G70
RLO
Can you add under the seat subwoofers to a standard 2019 G70 2.0t system
Welcome aboard! And thank you for signing up. Just letting you know that I've moved this topic our of the community lounge and into the Genesis G70 forum...
If you mean the same OEM subwoofer enclosures that came with higher trim G70's, then yes. I just bought a set of L and R underseat subs on ebay and will be installing them in my 2.0T Stinger (same chassis) when I get some time, probably later this year during the holidays. The cavities meant for these subs are built in to the floor pan. You will need to run a separate subwoofer amp to drive them. Source L & R channels can be tapped from the wiring harness that feed into the OEM amp that is mounted behind the passenger side rear wheel well.
Check out this guy's YT channel. He has done a lot of work on his Stinger, including sub amp install. Much of it is good reference material for the G70.
