Adjusting Headlights
rkar
39
I lowered my car, now my headlights are pointing lower I believe and I need to adjust them. Anyone know how to properly adjust them on a G70? Thanks!!
jfgenesis
2
Old thread, but I just adjusted mine. Super easy. Long flat tip screw driver, reach down and turn the geared nut by pushing on the gear teeth. Took 5 mins once I figured it out.
i constantly get flashed as if oncomers think my hi beams are on when they are not.. the dealer said they were aimed as they should be.. woudl you advise doing this anyhow to lower them a bit?
Cgo
810
93
Line your car up on a level wall and turn the lights on. You should have a clean, straight line across. That line should break about waist high.
That said, LEDs are bright and other drivers typically assume your high beams are on especially if you're creating a hill. Not much you can do about that. I'd probably leave them alone if the break line is straight.
