CarlitoGR
- Mar 10, 2017
- Location
- Maryland
So, I thought I would try to save some money and get my front/rear pads and rotors from AutoZone vs the dealer.
Aftermarket front/rear rotors and pads and parking brake shoes: $420
That was a mistake. I installed the front rotors and pads, torqued everything down to spec and went for a test drive. It wasn't bad, at least that's what I thought. The next day I was driving the kids to school and the was a definite shudder/wobble at highway speed and my stopping distance seemed like it was slightly increased, very annoying. At first, I thought maybe the pad needed to break-in. but after a week it got worse. So I took the car into the dealer to make sure that I did the brake job right. They said everything was installed correctly but the aftermarket rotors have too smooth of a surface that is preventing the pads from gripping. I looked at the guy like he had three heads and said thank you. But Then I said to myself, self, get the OEM parts and see what's up.
OEM front rotors and pads: $450
So, this past Saturday I put on the OEM fronts and when I tell you the result was ABSOLUTE NIGHT AND DAY. I torqued everything down the same way, removed and installed the same way and the braking was butter smooth and no wobble. I couldn't believe it.
In years past I have always gotten my brake parts from Advance Auto, Autozone Pep Boys, etc.. For this car, however, don't be like me, go straight to OEM and do not pass go from Carquest, you'll save time and frustration. You won't save money but hey, it is a Genesis.
Carquest Rotors
After two weeks this is the Carquest rotor. Rusty and you can see the wear pattern for the pad break in.
OEM Rotors
A circular finish from the factory and painted hub to prevent that rusty look
Carquest Rotors
OEM Rotors
