Advice Needed
ajredaelli
FL
I have a 2009 Sedan, 4.6. One of my fog lights and one of my "dome"lights, by the back seat, are not working. Can I please get some advice on the right bulbs to replace them? Also, has any of you replaced those bulbs? It seems so tight for a 250 pound man to get under the front of the car :) Also, any advice of removing the dome to change the bulbs would be appreciated.
Thanks!
Here it is:
Genesis Sedan bulb sizes
High beam halogen: H7
Low beam halogen (non-HID models): H11
Fog lights: H8
Front "parking" light (next to the high beam bulb): 168/194
Front blinkers: 2357. 1157 replacement bulbs will fit right in and work just as well.
Rear blinkers: PY21W/7507 (looks like an 1156 BUT IT IS NOT ONE!!!)
Back-up lights: 921
License plate: 2x 37mm festoon
Courtesy lights (under doors): 194/168
Trunk: 2x 31mm festoon (6418)
Glove box: 31mm festoon (6418)
Vanity mirror: 31mm festoon (6418)
Inside ceiling lights: appear to be custom lights, each with 1 high-power LED
Front footwell area: 194/168
There are some old threads on how to replace the fog lights on that model. Be very careful to get the right bulb because some bulbs get too hot and will melt the cheap plastic/paper housing around the fog lamp if they get too hot.
Advice Given - Get a 200 lb man to climb under the car.
Makes sense. Thanks.
- - - Updated - - -
I will look for that 200 pound guy. Bottom line is I have to find a way to lift it. Thanks!
- - - Updated - - -
Awesome - Thanks! Great help.
