AEB,TPMS, ABS, TCS. help.
wade0809
Hey guys. I have a 15’ genesis 5.0 ultimate. I currently have the Check AEB light, check TPMS light, abs light, cruise control doesn’t work, and I believe the traction control light.
the AEB light popped up out of nowhere. It wasn’t raining, the weather was 90 and sunny out. Once that light came on. The service TPMS light came on. seems like all these are connected to the AEB system. please note I did have a bad valve steam I just had replaced. I’m hoping if I replace all the TPMS everything will go away. Anyone else have this problem?
I have this problem currently, did you ever figure it out? Because I cant. About to do a master reset and see if that helps
First thing that popped into my mind is a faulty ABS sensor but a faulty Tpms sensor can cause the same warning lights if it's showing a very low tyre pressure.
You can try a reset of the Tpms system. Does the car show you which tyre is "low" or is it just a dash light?
Any solution here? I’m having the same problem. Very irritating.
A problem with the ABS will cause all those other lights too.
Since it could be hundreds of causes, wild guesses aren't likely to help too much. If you have the right tools, get the OBD2 codes from the ABS and post them here. Otherwise, get it diagnosed.
Yes, there is a solution finally. The answer is to get the OBD two sensor checks and I went to AutoZone to get that done. They have a good machine and they do it for free when they did it. It ended up being the ABS wheel speed sensor on the left-hand side since all these components work together to stop or start the car with the AEB system. It was a likely problem that was confirmed by AutoZone. I change the sensor. Everything’s good now.
