3.3T AEM intake install + more
Toddasaurus
REEEEEEEEEEEEEEEE!!!!!
3,076
3,931
^ looks awesome!!
But to be clear...you bought the kit which came with the filters...than you disregarded those and got the bigger filters. How much money did all this cost?
How do these bigger filters compare to the BMS kit which I believe uses K&N?
Thanks!
Filters were I think about $60 a piece. I got the intake from vividracing and used a coupon code, but I can't remember how much it ended up being.. a little less than the $380 advertised price. I bought the aFe filters for more power! The AEM filters, while adequate, don't seem to have much more surface area than the stock panels. More surface area = more flow. Every little bit helps!
I was originally planning on getting the Agency Power intakes which are over $500, so I'm still paying less than what that kit would've cost, all while having equivalent air filters and heat shielding, along with (possibly) better fitment. I'm okay with that.
trdehmer
44
ID of the aFe filters are the same as the AEM filters, which are huge... I can't remember the diameter off the top of my head. I'm sorry! But yes, the AEM heat shields should fit with the OEM intake elbows. Also, I completely agree. I was hoping the AEM heat shields were plastic, but alas, they're steel.
Anyway, the AEM/aFe filters have a very large flange diameter due to the velocity stacks that are part of the AEM kit. That said, you should still be able to find a large cone filter that will fit the OEM intake elbows without too much difficulty.
If you'd like, I can take some measurements of the room within the AEM heatshields so you can get an estimate for the filter sizes you could use!
Yeah, it would be nice to have some measurements of the room within the AEM heatshields if you have a chance to measure...
trdehmer
44
I really like the Agency Intakes too. Still probably my favorite design out there. But really want something that utilizes OEM intake tubes for ease of changing back to stock quick. I went from JB4 installed to OEM intakes all back to stock in less than an hour last night.
Thanks!
Toddasaurus
3,076
3,931
Update: Just finished logging some runs to check IAT's on stock vs AEM - looks like the numbers are almost identical between the two. That said, AEM intakes do not bring in any hotter air than the OEM intake setup does when doing 6 essentially back to back WOT runs up to about 80-85mph (top of 3rd gear). Things may be different during city driving while sitting in traffic for long periods of time....
trdehmer
44
I'd agree with Todd's findings. I watched IAT's this morning after doing my set-up last night which is the AEM shielding with the Spectre filters and OEM intake Tubes. I feel like the temps stay similar to OEM, and once the engine bay is heat soaked it seems the temps come down quicker when in motion during stop/go traffic.
The drivers side turned out good as the OEM intake tube holds the filter in place good. The passengers side I need to figure out how to hold the filter up against the AEM shielding as right I'm using zip ties and a Velcro strap to reduce it from bouncing around until I figure out a long term solution. Getting the passengers side filter to be a tight fit against the AEM shielding is what I need to figure out somehow...
I had to make the opening about 5.5" diameter to allow the Spectre filter to fit.
pulsar
529
411
63
DFW, TX
Thanks for the pics. I like the looks of this setup since stock intact tubes are used. Would be interesting if someone had access to a flow bench to check flow of stock filter box, stock box with an after market hi-flow filter, then with the box removed and one of the round air filters to see what measurable differences are since these kits are a little pricey. When I rode Harley’s, just about everyone had hi-flow filters and they could easily add 3 to 7hp and even more with a pipe change so I believe in the process.
DonMufti
Diverter valve hose removal on the passenger side....
Vacuum hoses unclamped on the driver's side...
Now, loosen the clamp that attaches each intake elbow to their respective turbo...
Now you transfer over the vacuum tubes to the driver's side elbow, use the silicone coupling to attach it to the turbo.
Attach your vacuum hoses. This nipple, I found, was a little too small in diameter. The kit includes a different clamp to put on to make it tighter, but I wanted to adjust things by simply adding some duct tape to make it thicker, then installed the clamp..
Continued...
Hey there,
Really grateful that you took the time to post this bit of information on here. Got me motivated to get one myself. However, ive been having a hard time finding an intake for the 2019 g70. Are you ordering the part for the kia stinger??
Toddasaurus
3,076
3,931
Hey there,
Yes. I ordered the Kia Stinger specific AEM intake. Both G70 and Stinger intakes are identical.
Toddasaurus
3,076
3,931
Hey @Toddasaurus , great write up as usual. Really, really appreciate your contributions to this forum! 💯 :cool:
Question: Are those the Stinger Intakes from AEM? PN: 21-849DS AEM COLD AIR INTAKE SYSTEM. I didn't see a PN in your post so just want to make sure I get the right thing before ordering.
Thanks.
Yup, that's the exact one I bought!
Jtripi
TBH I recommend getting Bigmouth snorkels to get rid of the restriction the stock snorkels have. Here is a photo of my AEMs with Snorkels. Makes for a true cold air almost. (Agency Power Intercooler too 😂)
Toddasaurus
3,076
3,931
Yeah man! I've got VT snorkels as well.
Ever since I installed them I notice a slight whistling sound when flooring it at high RPM's, it kind of sounds like it's moving even more air. Pretty cool.
Waiting for Mishimoto to come out with their IC as my next upgrade. Then I'll go from there.
Jtripi
Once you get the intercooler you'll feel even more of a difference. But I definetly feel it already. The snorkels really did eliminate a lot of restricted air flow for sure. I dont know if you noticed the older ones design
Jtripi
Do the snorkels give the car a more power feel? Wondering since it could yield colder intake temps with less restriction from outside air
Personally I think so. Especially when you've done a few hits and want to go again. I feel as though the hot air from the engine doesn't affect anything anymore. It's almost as if they're sitting in the front. Throttle response is way better too. My intercooler also helps with cooler temps so it's hard to tell the difference since I installed them at the same time. But well worth doing with any intake out there right now
Vortex951
805
93
I’ve been reconsidering the bms intakes I have on my car. Nothing wrong with them just not a huge fan of how little shielding there is from any heat what so ever
Jtripi
Not only that look at the direction they're facing. They're more of a true ram air. Yes they have their gains but like you said, no shielding. I just felt like there was a reason they were cheaper. I wanted agency but was told the aem fits better than any others right now. Plus I wanted heat shielding for more cooler air
Vortex951
805
93
I might end up getting the aem to try those out. We shall see though. I’d like an intercooler first. There just isn’t a ton a kits that have piping also
Jtripi
Yeah I agree. The agency power didnt come with piping, but the original piping on the car I believe is coated already for heat protection so I wasnt too disappointed. I can always replace it later. It was originally 900 bucks that i got for 550 on black friday so one heck of a deal. I'm impressed with the aem, had it on my 16 gen coupe too. Great customer service!
Pedal Commander
