After a year and a half - my first problem
earlinjax
Finally, had to take the Gennie in for a problem. It would not go into park while the brake pedal was depressed. The service writer was well aware of the problem-a $7 switch between brakes and transmission. FWIW, he said Audi and Ford were plagued with the same problem.
Have to say I have been super satisfied with the Genesis. (Yes, I do have the problem with droopy steering wheel, but it is easily reset every few weeks)
Earlinjax
Earlinjax
There is a for sure fix to the steering wheel now. A module and switch replacement. I think it takes about 1. 5 hours for the warranty service.
I could be wrong... but I think that was common on some Kias and Huyndais. I think there's a little key hole near the shifter. If you pop that open, I think you're able to override the lock.
Again... never happened to me, but I have seen it. And this might not be related at all.
The brake pedal switch failure is common across many Hyundai and Kia platforms. My 2011 Sonata w/keyless had the same issue around 10k miles. Not sure if Hyundai is revising the part or not, but it happens A LOT.
For the keyless guys who have this problem, you should be able to hold down the start button for 30 sec to override the brake switch. However, you'll notice that your brake lights don't work either. I'd press to get the dealer to tow it to save you from possibly being rear ended.
