After differential fluid change
G70Matt4
I have a 2019 G70 2.0 rear wheel drive. Was hearing a slight whine from the differential so I changed the fluid with red line fluid(the 75w) with the 4 ounces of redline sliplock. Still makes the same noise. Is it a automatic differential change? Not sure if it matters or not but the only time it makes any noise is when I'm at 35 mph or above and only when I just barely touch the gas pedal or when I let up on the gas pedal.
