Aftermarket front camera power source
Noavt
All:
I have installed an aftermarket camera on the front grille of my 2015 Genesis sedan 3.8 ultimate to help prevent hitting those pesky concrete parking barriers found in some parking lots. Everything works well (the camera emits a Wi-Fi signal to which I connect my iphone when parking and I can have an unobstructed view in front of me). I connected the wires to the battery positive terminal found under the hood and an unpainted screw. However, last night I became aware that, because the camera is always on and emitting the Wi-Fi signal, I could drain the battery.
What fuse/connection can I tap into (preferably under the hood), so the camera is energized while the car is running, but not when the car engine is off?
Thanks in advance.
Actually I found the power source to the cigarette lighters do the trick. I selected these because they are not energized when the car is off and if there is a problem I would not compromise more sensitive systems.
Can you please share where did you plug the wires. Trying to do the same
