air suspension
  • Thread author Thread author G-685753
  • Start date Start date
G
G-685753
front suspension bottomed out sometimes would lift sometimes not now stuck all the way down and
d will not even take air manually from the air port
First, I think you have to make sure you don't have any fault codes. Next, make sure the pressure is high enough on the compressor you're using. The suspension TSB mentions 175 psi, but it's worked when I've used 120 psi.
