Alignment
dudmleh522
Just got alignment done because I put new tires on the rear and my car was pulling right severely.
Do these specs right to you? I got the alignment done at Firestone.
The guy said rear camber is cannot be adjusted further that is closest he can get.
I am not a mechanic but it seems that there should be a reason why he can't get them to match or get them to ideal adjustment. Did he say if something was bent or wrong?
Nothing is wrong. He daid they are within spec (in green)
Here is mine '15 5.0 back in 2016, after I lowered it on Ark Springs.
Dareck, your measurements "after" make more sense to me as they are a closer match in the numbers indicated from L and R sides.
But I know nothing! Just saying....
Oh ok. Hows the ride after lowering it with spring?
I lowered my genesis coupe with Eibach sportline spring and its really firm
It felt good, but I'm talking about GT-F springs, the drop all around was ~.75. I had the GT-S first and the front were terrible, sunk in ~1.75!
Now I have the G80 sport AWD with adaptive control suspension and I'm not touching it....springs are about 10% stiffer than "regular" Genesis's suspension.
Oh ok. Wish i had the g80.
Anyways you think my alignment specs look good?
As long as the numbers are within factory specs, you should be OK. It shouldn't pull to either side, but if it does, then something is wrong.
I'm pretty sure those are 18x8 et40
It's an offset 40, marked "et" often.
No, it never has. The car drives in straight line before and after. Same with the G80 sport.
