All Climate controls nonresponsive...
crizzlec
Just went out to the car to run to the store and all of the climate controls are unresponsive. Did some searching in the forum to see if anyone else has had this issue, but couldn't find anything.
None of the climate control buttons work, the fan isn't running, heated/cooled seats aren't working. No CEL/warning lights in the cluster either. Just really odd symptoms. Possibly a blown fuse?
Welp. Looks like I'll be visiting the dealer tomorrow. Pulled the battery for 30 minutes and no change.
Pulled out the good ol' paper manual and tracked down the fuse and a spare. 10A to the A/C control module had blown. Will need to keep an eye on it but things are back up and running now
Looks like your first hunch was a bullseye. Glad it was minor and you're back up and runnin'. (y)
I have a 2019 G70, the climate control is not working as well (all the lights are on, no fan or air from vents) the dealer first said it was a relay, replaced it and worked for a day or two then stopped. Second time the dealer said nothing is wrong, bring back when the issue is live, brought in the next day. They did some pocking around and said the blower fan is bad, must replace it. They did, it worked for a day then stopped. Going back and this time with a lemon law form.
Are you hearing anything from the climate control system? Blend doors moving, blower, etc? If not, check the fuses first. After that, they need to test the refrigerant levels and compressor.
