Am I able to do this? Will it work..
Rocklyn
Hampton, GA
I have a 2015 Genesis sedan fully loaded and want to know are you able to replace the headlights with the G80 full led headlights on mine? Will it be a direct fit and just plug straight up, or will modifications need to be made if it does fit..
I doubt that there's any chance that it will just plug in, though I don't know for a fact. I suspect that if you really want this, it may be cheaper to trade your 2015 on a 2018. It's not just the lights, it's also the sensors (such as ride height sensors), the wiring harnesses, and the electronic modules and programming involved.
Very different wiring harness, will require a relay controller with some logic onboard to handle switching from DRL to Turn signal.
Got you preciate that
