Amp adjustments ??
Hopgo
Does anyone know if there are any adjustments on the amp itself on the 2015 Lexicon 17 speaker system ?? Gain ??
other than what you are able to control through the head unit I do not believe there is any additional way to fine tune the sub. I am by no means an audio expert so others may have better advice for you on this front.
I believe that is correct. The system is totally integrated, including specific equalization for the interior of the Genesis and adjusting for the characteristics (impedance, frequency response) of each speaker.
has anyone experienced issues with the radio, at times if I have the volume up to 13 on an HD station, it sounds great and majority of the time same station, I have to turn the volume up to 23 to get the same sound that volume level 13 produced a couple of days earlier..
It is all the quality signal coming in. If I listen to XM I have to crank it up higher than when I listen to Pandora. Same goes between HD and no HD stations.
There have been complaints. Trying using google search with domain genesisowners.com
I'm not too impressed with HD radio. It can be very variable in quality and sometimes sounds pretty bad - especially if an AM talk radio station is using it. It''s particularly annoying if the HD signal comes and goes and the volume keeps jumping.
ok, so it's not just me, feel better...thanks Nikgen
You can uncheck HD so it doesn't kick on or off.
