**AMS PRODUCT RELEASE** Genesis Coupe Fuel Rail fitting
Eric@AMS
The AMS Hyundai Genesis 2.0T Fuel Rail fitting. AMS has come up with a simple but very effective way to install a fuel pressure regulator in your factory fuel rail. We were able to develop a custom CNC’d -4 fitting allowing the end of the fuel rail to be converted to a -4 an fitting. Installation is a breeze. Simply remove the clip holding in the factory rail plug, remove the plug and transfer over the O-rings and install the AMS -4 fitting.
Exclusive Features
* Direct factory replacement with NO cutting or trimming required
* Professional CNC machined for precise fitment
* OEM like fitment and clean look
* Allows the use of both factory o-rings for a fuel tight seal
* Simple installation and easily converted back to stock
Specifications
* 6061 T6 aluminum
* Hard coat anodized for fuel safety and corrosion resistance
Applications
* Hyundai Genesis Coupe 2.0T models
Fits all USDM and KDM models
$29.95
nicksdaddy
Exclusive Features
Specifications
* 6061 T6 aluminum
Applications
$29.95
Hi Eric,
You still around?
