I've gone through past comments and can't seem to narrow down which actuator I need.
Issue: no heat or cool on drivers side. It just seems to blow ambient temp regardless of temp setting. The Passenger side works (heat and cold). I can redirect flow to defroster, front console and to feet (so mode control OK). There are a bunch of actuators and I'm not sure which ones just ones set the temperature.
I see from various parts diagrams and the service manual for the driver's side:
temp actuator (drive) 97159F p/n 97159-3M000
console temp actuator (A) 97160E p/n 97160-3M500 also see it called ACTUATOR ASSEMBLY-CON.TEMPERATURE RIGHT
console temp actuator 97160D p/n 97160-3M000 also see it called ACTUATOR ASSEMBLY-CON.TEMPERATURE LEFT
mode actuator 97256D and p/n 97154-3M000 (pretty sure it isn't this as this is the mode control but included for ref).
