Any options for "camber" bolts?
TylerDH
Omaha NE
I just lowered my 2015 htrac with Ark GT-S springs. The alignment shop stated that the front and rear camber cannot be adjusted anymore and will cause pre-mature tire wear. Are there any camber bolts out there that work with our cars to get to the right adjustment when lowered? Thanks!
I'm lowered on GT-F springs but I haven't been able to find any way to adjust camber so I would like to know too.
I could only find kits for the GH front end :( - edit - oops BH
or if anyone can tell me if our cars use a 14mm bolt or what size it is? or, do we not have a "bolt" system and we need to do "shims"?
yes there is a company that has come out with a Fixed camber adjustment where you can get 1.2 degree positive or negative but now adjustable
Re: Any options for "camber" bolts?
more details on this would be greatly appreciated by myself and many others on this forum that are lowered. thanks!!
- - - Updated - - -
i would be interested in the fronts as well (i think they are off just a bit as well), the rears are definitely the worst. what kit is out there for the front? thanks for your help!!
the only ones i found so far are first gen, not for ours, I would imagine it is just a matter of time before eibach, SPC, Moog, or someone else makes some
Do you have any info on the camber bolts for the DH 2015 5.0 models?
This may help. Not sure if it only works on BH or not.
