Anyone squeeze 295/30R20s in the rear?
gkra
2
San Diego, CA
I keep thinking I want to run a wider wheel/tire at the rear, and was wondering if anyone’s squeezed a 295/30R20 on 20x10s in the rear? With Storm springs?
I’m trying to keep the same diameter as the fronts, where I’d like to run 255/35R20’s on a 20x9 rim, since I’ve got AWD and consensus online seems to be that you need to keep the difference in diameter front to rear under 1%...
I’ve seen others here running 285/30R20’s, but that’s 1.1%, and I’d like to not strain the AWD if possible... otherwise I might just give up and run square on the 20x9’s.
azollars
SF Bay Area, NorCAL
Tried it with 20x10,40 offset in rear (not lowered) and it was a no go with anyone sitting in the back seat as it bottomed out frequently. I posted that in a separate thread. It was rubbing on inside liner at roughly 2 o'clock position when looking at driver side rear (10pm on passenger side rear). It may work with a larger offset (say 45 rear) but I already had purchased my wheels. Hope this helps.
gkra
2
San Diego, CA
Thanks for the note. Been trying to search threads here, but don't always come up with ones with the answers I'm looking for. :)
After much consideration, I'm thinking keeping the replacement wheels to 9" width and tires no more than 255, I should be OK and still get a good look on the car.
Now I just have to figure out if I really want 20" or want to be more conservative and stick with 19"...
Pedal Commander
