Apple Car Play Constantly Disconnects Help!!
Rampy
Genesis GV80
I always plug into the USB port and use Apple CarPlay and/or Waze instead of the onboard navigation system
Seems like every 10-15 minutes for no reason the car disconnects from Apple CarPlay & I have to unplug wait 10 seconds and plug the phone back in.
How do I stop this from happening??
Try pinching your wired USB end just enough to create a tighter fit to the car's USB.
Try a few different cables. I know android auto is very fussy about the cable you use, Apple might be the same.
I gave up as nothing seems to fix the problem, tried 3 different cables and it still did it
Went and ordered a expensive Anker high speed USB 3.0 cable, will see if that fixes the issue
I’ve been having the same problem.
Did your Anker cable solve the issue?
Thank you!!
Thank you!!
Agreed... tried numerous cables of high quality/high speed. Nothing worked for me. So frustrating.
Execute an infotainment [full reset] if you've already tried deleting said phone from system and [restarting] the infotainment system, and rebinding said phone. If you have not, do this 1st. Be aware for the [full reset], that you'll have to setup the entire system again but typically it solves just about any issue.
Thanks for the suggestion...tried this with no luck.
I had the same issue. Took it to the dealer this week and there is a software update for Apple car play. After the download Apple car play loaded immediately and have no issue now. Hope this helps.
