ARK GT-F Springs Installed
CoconutRob
467
63
Can you provide a link showing which spring compressor you used? I'm pondering tackling this project, and my spring compressor is the more typical style. I just installed my ATQ subframe collars, and discovered that I may need an alignment check, so I figured I might just get some lowering springs and make the alignment actually worth it. :LOL:
CoconutRob
467
63
Be careful using these. My buddy used those, from ebay purchased, to change spings in his acura mdx and one of the compressors broke. Thankfully no one was injured.
I think they are perfect for our application. Barely compress the springs . Worked fine for me and you cant position 180 degrees apart.
Cgo
756
93
How did you position them?
CoconutRob
467
63
Once you Jack it up and take the wheel off, one one each side as close to 180 as possible
tumtum
17
johnny3fingers
27
North Wales, Pensyltuckey
Guessing springs are settled now. Arks posted drop specs seem accurate to you?
I wasnt going to drop my car (2016 v6 sedan) but the specs for my car my don't look overly aggressive. Basically going to close the gap slightly, provided below is accurate.
VEHICLE APPLICATION
Make / ModelFits: 15-16 Genesis Sedan 3.8L and 5.0L
PERFORMANCE SPRINGS INFORMATION
Front DropEstimated: 0.50 Inch (V6) / .75 Inch (V8)
Rear DropEstimated: 0.75 Inch (v6) / 1 Inch (V8)
CoconutRob
467
63
Do you still clear parking curbs just fine and do you have any problems with scraping? Also, did you notice reduced body roll when taking corners? I know when I do canyon runs the body roll is horrible. The car looks great though.
No problem with curbs yet. No scraping (it's only 1 " lower). Yes a little stiffer and slight roll reduction. I dont do canyon runs. Basically just wanted to drop it slightly. The small improvement in handling was a bonus.
Toddasaurus
REEEEEEEEEEEEEEEE!!!!!
3,186
4,173
I want to call the ARK springs the GTFO springs. I mean, they're only one vowel away from it anyway...
surprisinguy
144
43
NC
Looks nice! I's amazing what a difference a drop makes on these cars
CoconutRob
467
63
Pic with 235s on front and 265 on rear NO 5mm spacers. I liked the look with the spacers but not enough hub.
Genesisderrick
27
LOOKS GOOD, I AM HAVING THE GTF INSTALLED TOMORROW, I ALREADY HAVE 20 MM SPACERS ALL THE WAY AROUND.
CoconutRob
467
63
Sweet. I would like to see with the 20mm spacers
MG8
Proud owner of two Genesis vehicles
963
586
93
San Francisco/Las Vegas
spacers look good , but honestly not digging what he did to his headlights.
