ARRRRGHHHHH bent a rim!
maxsilver
238
43
I hit a nasty f$%king pothole on my way to work this morning (dark/wet street, didn't even see the damn thing) and have ended up with a bent rim. Has anyone experienced this before? The car didn't show any obvious trouble signs immediately, but it was only a minute or two away from work at that point. I have Fast wheels for my winter setup, I'll look around locally for somewhere that can repair the wheel.
Has anyone had a bent rim repaired before? How were the results aesthetically and functionally? I'm tempted just to try to get a replacement rim instead since they don't cost a ton, the whole set was only in the neighborhood of $1000 CDN or so.
Beefer
I’m faster
4,483
3,960
Richmond, VA
I don't think you can fix a bent rim. Integrity might be compromised. I think you can only fix scratches/marks, etc.
If the rim is not to bad...perhaps you can keep it and hopefully it can be re-balanced somehow. Clean it up so it's not so obvious.
maxsilver
238
43
tarhoosier
532
93
Charlotte
I cracked an alloy rim on a Volvo a few years ago. Tire would not hold air was the clue. Rim shop did quality weld and I ran it for a month or two until I decided to buy a new wheel and use the repaired one as a spare. Sold the car with the repaired wheel on car and then sold new-ish wheel on Ebay.
maxsilver
238
43
I'm thinking of doing something similar, getting the rim repaired for the time being, and buying a new one after winter is over. I would then keep the repaired rim as a spare afterwards. I can't safely run my summer setup for another couple months unfortunately as we tend to get snow even going into May here from time to time.
jimmy buoy
303
101
43
Sarnia, Ontario, Canada
Don't fret. You can absolutely have a bent rim repaired and it will be as good as new. There are various shops in my area that perform this service and I'm would be surprised if there were none in your area. They will even repair broken aluminum rims by welding new aluminum pieces into the wheel and then grinding/machining the wheel back to specs.
I've not had a bent rim repaired, but a curbed rim of mine was repaired. While there, the owner showed me a broken rim that was in the process of being repaired. I was surprised just how much damage is able to be repaired on aluminum rims!
maxsilver
238
43
I got my repaired rim back from the shop that did the work for me, and the visual result was decent but not perfect. I could likely live with the small visible defect but a bigger issue popped up in that the tire is losing air pressure now. It's a decent size leak, about 1 psi/hour or so. Thankfully I have easy access to compressed air at home and at work so I can top the tire up before each drive for the weekend. The shop owner said they will try to repair the rim again on Monday, hopefully it holds air properly this time. 20200307_144603.jpg
johnny3fingers
22
North Wales, Pensyltuckey
The biggest issue with a repair is the integrity of the wheel after a repair. I personally don't think a repair is worth it, particularly on a less expensive wheel. A new wheel is about $200, which is roughly the same price as a repair.
would love to know where youre buying wheels.
Mine were $400 ea......if I ever curb or hit a pothole $125-$150 repair/paint is the way I am going.
Ive had a few wheels repaired and you would never know unless I told you and never had a safety issue with any of them
maxsilver
238
43
Thought I'd offer up a final update, after getting the wheel worked on again the repair shop said they patched up a leak from the tire itself. The leak is slowed down, but unfortunately the wheel/tire are still leaking a tiny amount. It seems impossible to tell if the issue is the wheel or the tire at this point. I think I'll get the tire remounted on a new rim if I can get my hands on one, I ordered it directly from Genesis originally, hopefully they can still obtain another one for me.
ft55555
5
This site has the sport rims for $300:
Genesis G70 2019 19" OEM Front Wheel Rim
16UltV6Guy
I quit!!!!
259
142
43
Jax, FL
^Nice! I think that's the best deal yet on OEM rims.
Please note that those are NOT brand new rims. They apparently are factory oem rims, but are not brand new. The following quote is from the "product description" page of that link:
"The wheel has been professionally refinished to like new condition in both quality and performance..."
Pedal Commander
