Automatic Seat Warmer/Cooler
Jim C
Genesis G90
Does anyone know if the 21 g90 has auto seat warmer. In my 2019 g90 when you start the car the seat warmer defaults to off. I was told the new 20 and 21 models, like my caddy, have an option to turn on the seat warmer when the car is remotely started if the temperature is below say 40 degrees. Can not find the info online. Thanks
dmchen
13
Genesis G90
If you use the app, you can create multiple remote start "profiles" and can not only set the seat, but also the AC/heat, vents, and even the steering wheel heater. I have one for Winter, Summer, and Normal (for Spring/Fall), and I change which one is my default at the start of each season. I do not think you can have any automatic settings when you manually start the car unfortunately.
CarDriver
5
Genesis G90
My 2021 G90 allows me to remotely start via the app and at the same time you are able to preconfigure air-conditioning and heater settings for the drivers seat. Hope that helps.
