Bad battery connection need help!
Jeslorraine
1G Genesis Coupe (2009-2016)
Battery isnt dead ....when I turn it over to start it clicks like it's dead but everything turns on but the car. Anyone else had this problem
Welcome! Just letting you know that I moved this topic out of the community lounge and into the Genesis Coupe forum...
Did you check the battery for actual voltage? May be able to turn on light but not turn the starter.
You mention connector. Did you take them off and clean? If corrosion you can replace them.
What bout the connection at the other end? Any corrosion there?
It registers bad connection but where do I start with that if I replaced my battery checked all my fuses could it be the connection to the posts in the hood that lead to the battery in the trunk is it possible I need to change the whole front end battery post charger box? Has anyone had this problem with their genesis
