Battery charger connections
Shark88
Genesis GV80
I have had problems with my 2025 GV80 battery discharging fairly rapidly when not run for long drives. I bought a maintainer but where do I attach the positive clamp? The picture in the manual is blurry.
There is a little hatch with a "+" on it that snaps off, directly aft of the fusebox where you hook up the negative clip. You will find a bolt under the hatch that sticks up, to attach the positive clip to. Once you know where it is, you can reach around the hatch too, if you don't feel like snapping it on and off all the time.
Here's where it goes in my G70
One more time for this visual guide...
Thanks! In my 2025 GV80, there appear to be two positive points for connection: one is a small bolt with a red dot on it and the othere a silver square jutting up from the fusebox. Are these both valid connections for the positive terminal?
Probably but I would use the silver square. In my manual, Genesis puts the "reference number" just to the right of the connection point ( see A and B as per below).
