SKM348
- Mar 30, 2015
- Location
- TN
Have a 2015 3.8. Left door open and drained battery. Finally got trunk open using a pole through the pass through opening (Did not realize there’s a key slot under far right of trunk lid!)
- To trickle charge or jump start do I have to remove both +/- cables from terminals or can I attach jumper or trickle charger cables with Existing Cables attached?
- Should I jump or trickle charge it - is one approach better than other. I don’t want to fry anything. Car has 72K on it and battery is orginal but performs well.
- Do I also remove ‘flat’ positive cable in addition to the cable on the positive post?
- Any other tips/advice appreciated
