Battery drain issue - 2024 GV80
wonoh
Genesis GV80
Since late July, my vehicle has experienced a recurring parasitic battery drain and multiple electrical system warnings.
Timeline Overview:
  • 07/31: “Stop the engine and check the brake system” warning appeared; dealer found no issues.
  • 08/02–08/04: Battery completely dead; car towed and recharged, no issue found.
  • 08/07: Same brake warning returned; instrument cluster malfunctioned and was replaced.
  • 08/17–08/22: “Low engine oil” warning appeared; technician confirmed low oil level and replaced the oil sensor.
  • 08/31–09/15: Battery died again; dealer confirmed ongoing battery drainage but couldn’t identify the root cause.
  • 09/26: Genesis Customer Affairs stated the case doesn’t qualify under the PA Lemon Law due to vehicle age.
  • 10/08: Dealership replaced the battery with a new one.
  • 10/19–10/20: Battery dropped from 76% to 26% overnight; Genesis tech line suggested possible Steering Wheel Control Module (SCM) issue.
  • 11/04: SCM replaced.
  • 11/08: Battery drained again overnight — issue still unresolved.
Despite multiple visits, component replacements (instrument cluster, oil sensor, battery, SCM), and dealership diagnostics, the battery continues to drain overnight while parked, and the root cause remains unidentified.
Has anyone else experienced a similar parasitic battery drain issue on your Genesis GV80? If so, were you able to identify the root cause or find a permanent resolution? This is so frustrating.
Battery drains that kill batteries overnight should be easy to diagnose. A simple test: get a small 12volt light bulb, like a dome light (not a LED version) or a small side marker light bulb and socket with wires. Unhook the battery positive cable (red wire/cover) and slip the light between the cable and the battery positive post. If the light glows much at all there is a power drain. Just opening a door, or hitting the key FOB unlock, to wake up the car is enough. Open the hood and both front doors so you can access the fuses. Use tape to hold the door closed sense switches located in the bodywork structure. Then use a screwdriver shank in the door latch mechanism which is on the back edge of the door - it'll be a rather beefy metal claw - use the screwdriver shank to push the crotch of the claw towards the outside of the door; basically the same thing as the "U" shaped metal piece on the bodywork does when you close the door. Do that to both front doors. And tape the hood open sensor (look for a rubber bumper along the edge of the hood, see what it pushes on when the hood is closed to locate that switch) in the hood-closed position. Basically do everything to make the car electronics think all doors, trunk/hatch, and hood are closed. Wait 20 minutes for the electronics to "time out" and go to full standby mode. At this point our little test lamp should not be glowing. If it is... something is still drawing electrical current. Unplug a fuse and see if that makes the light go out, or at least get a lot dimmer, to see what circuits are drawing current. No change in the bulb? Put the fuse back and try another. Note: cycle the interior door handles to open that beefy claw before you try closing the doors again!
Another thing that kills batteries quickly is a bad alternator. Modern alternators generate 3-phase electrical A/C power internally, that gets rectified (converted) to DC by a series of diodes. Think of diodes as wires that pass electrical current in only one direction. If one of those diodes fails by shorting out, it provides a low resistance short-circuit across the battery. A good alternator test machine can spot this as the DC output will be "lumpy" if 1 of the 3 phases isn't doing it's job. Dealers should be able to do this test. As an option, you can:
1: disconnect the battery negative post first, then disconnect the positive post.
2: Look at the alternator, you'll see a multi-wire connector and usually a separate wire that is much larger in cross section. Undo that wire - it's the charge wire from the alternator to the battery. And undo the multi-wire electrical connector.
3: reconnect the battery - positive post first, then negative. Do not start the engine until all tests are complete.
4: wait overnight.
5: if the battery is good then you've proven the alternator has issues. Undo the battery negative and then positive posts again, reconnect the alternator's beefy wire and electrical connector, then re-connect the battery positive and then the negative post and make the dealer test the alternator.
Why disconnect the battery when working with the alternator wiring? Simple: that beefy wire, and possibly some wires on the smaller connector, go straight to the battery positive post while the alternator's case is ground which is also the battery negative post. You don't want to create massive short circuits if your wrench or other tools happen to touch the fasteners holding the beefy wire and the alternator case at the same time. Lotsa sparks at least, maybe soiled underpants, and possibly fried wires from the short-circuit, would result if the battery were still connected to the car. Disconnecting both battery posts is somewhat overkill - just disconnecting the negative/black/ground is enough for this test. But, as a "safety thing" for other jobs (including replacing the battery), I am in the habit of doing both posts in the order specified to minimize the chances of accidental short-circuits with the tools. Even at the battery... your wrench could be tightening the positive post connector and bump the bodywork... if the negative post were connected that bodywork is ground and you'd have a spark show again. Shorting from the negative post to the bodywork is not an issue as they are normally connected anyways.
If you are tool handy and can remove the alternator, most good auto parts stores have test rigs that can verify the 3 phases are working, that there are no shorted diodes, etc. NAPA generally has the machines, call around your local auto parts stores and ask if they can test 2024 GV80 alternators for whichever engine you have.
What did the dealer do on the 8/31-9/15 visit to confirm a battery draw existing? Sounds like they measured the current flow which is what my light bulb test does. But what did they do after "yup, something is draining the battery" to identify WHAT was actually draining the battery? If all they did was look for computer error codes using the OBD-II port... they suck as diagnostic mechanics.
Note: as with many modern cars that have seat memories, power windows, power everything, those gizmos will need to be reset after doing my light bulb test. Just as they would need to be reset after changing the battery. The light bulb serves as a low cost amp meter (aka ammeter); a device used to measure electrical current flow. You can buy ammeters or multimeters that include ammeter functions (very common electrical tool) but most are limited to 10 or 20 amps max... Whatever is killing your battery may be sucking down more than that and would fry the fuse in the ammeter. A 12 volt light bulb is designed to be connected directly to a 12 volt battery source - it can't draw more than a few amps - and will serve as a current limiting device when connected as I described... even if whatever is killing your batteries is a direct short, the electrical current through the bulb would be no higher than it would be if the bulb were connected straight to the battery. Simple "two items in series resistance" electrical theory.
Before Genesis existed as a stand-alone brand, the early 2009 Hyundai Genesis sedans had a somewhat similar issue: the battery would drain in a day or two when the car was parked. The cause was that rubber bumper along the driver side edge of the hood being too short: it sometimes didn't fully press the "hood is closed" switch (also used by the car alarm) so the car thought "hood is open." Any door/hood/trunk being open caused the electronics to partially "wake up" or "boot up" which consumes a lot more energy than the fully OFF condition. After parking the car, and shutting off the engine, the electronics would go to a "standby" mode which used less electricity than fully ON but much more than fully OFF... that STANDBY mode would time out after 20 minutes or so; the electronics would then go fully OFF. For the 2009's with the Tech package, a blue light at the CD/DVD slot would blink a few times at this 20 minute point; once it stopped blinking the system was in full OFF mode. I'm not aware of any similar indication on GV80s. But if any door/hood/trunk switch indicated something was open, the electronics remained in STANDBY forever... or at least until the battery was dead. .. that blue light never blinked. There is a TSB for this rubber bumper. I don't know details on the 2024 GV80s; my 2021 GV80 doesn't have this bumper but it does seem to have a switch in the hood latch assembly that probably does the same thing.
mike c.
note: some folks say unplugging a battery on modern cars is a no-no. It certainly is if the engine is ON/running. But with everything off? The factory service manual will have guidelines on what is necessary to replace/disconnect the battery... dealers have this info. Owner's manuals in the maintenance section, especially if there are notes about how to replace the battery, will have warnings if such a procedure is not recommended. My 2021 owners manual specifically states to disconnect the battery if the car will be parked/stored for an extended time, especially if the weather is cold (BATTERY section in chapter 9), and lists the "reset" steps for the various electronic memories. So it is safe to disconnect the battery on 2021s. 2024 owners manuals probably have similar wording.
Great troubleshooting write up!
4: wait overnight.
mike c.
Thank you for the detailed reply, Mike. I’ll share this with the dealership.
To answer your question — according to them, they removed the fuses one at a time from the fuse box to isolate the circuit but were still unable to identify the root cause of the issue, even after checking each fuse individually. After completing all those tests, they contacted the Genesis tech line and reported that they had found the cause of the draw — it was intermittently reaching 70 milliamps when it should have been around 50 milliamps. They said this 70-milliamp draw was causing the issue and replaced the battery with a new one. Of course, that didn’t resolve the problem.
One strange thing I’ve noticed but forgot to mention earlier was that both incidents of complete battery drainage occurred on weekends (one on Saturday and one on Sunday). Since then, I’ve been monitoring the battery level through the Genesis Owner’s webpage once or twice a day, almost daily, and every time I’ve noticed a significant battery drain, it’s also been on a weekend. I find it odd that the drain seems to occur only on weekends. Could it just be a strange coincidence?
I've heard that leaving your Genesis unlocked will cause extra battery drain. Do you perhaps park it out unlocked in your garage all weekend?
Is it always parked in the same exact place and and in the same position overnight vs weekends? If so, perhaps a few additional weekend idle hours could breach the non-starting threshold, but that would be unusual. Are you opening the doors (and especially the trunk hood) several times or more on the weekends? A post on another thread complained his GV80 went dead when camping and traced it to multiple hatch openings by himself and his kids between re-starting car. He said (I have not checked this) that somewhere in the manual it says not to open the trunk hatch more that 3 times without re-starting the car. I keep both of my keys in a Faraday pouch at home so they cannot communicate with the vehicle ($12 Amazon). It would be a pain but you could also shut off connected services when the car is parked so that the car's cell radio is not communicating with Gen HQ every so often. Of course if you did this, then you could not check realtime battery status on your phone. I have also read that some vehicles get false positives on the proximity warning sensors when at stop lights if another sensored vehicle is too close (esp Ford pickups). I would not think this would happen if the car is shut off though, but perhaps if a neighbor has a Ford or there is something else close by in the position you put the car at night (anything with a communicating radio--smart outlets/lights/Alexa/router/motion sensors), could it be continuously getting and processing a signal like that? Those should be at different frequencies but you never know. And I am sure you have already confirmed that there are no external devices plugged into any of the 12v or usb ports (like an AA/Carplay transmitter) when you shut off the car? And you have gone out at night when the car has been shutoff for at least 30min to verify there are no lights internal or external on? (not trying to insult your intelligence, just coming up with everything possible you could check without the dealer). It seems that the best solution at the moment--at least until a proper diagnosis can be made--is to rig up an easily plugged in batter tender whenever the car sits for a while. This is also a pain to do each time, especially for a $75k new car, but car drivers in the far northern climes have been doing it with engine heaters (see cords with plugs protruding from lower radiators) for decades. Somewhere on one of these threads there is a good set of pics on how to do this with the attachment wires largely hidden behind and under the passenger wiper cowl, and running to the jump points under the hood. I spent a good bit of time in the trunk of the car under the floor board where the battery is located (installing a reverse terminal battery for cheaper and easier replacement). It is a poor design and clearance tolerances are not all that great. I would leave the floor tire cover open and the battery cover off one weekend and see if it still fails. And if you have the 3rd seat, try it both up and down overnight. One poster said she would get a short that killed the battery if she left the trunk area fully loaded overnight (she was moving houses), but not if it was empty. Really hope you find it. It is aggravating and stressful to have a worrisome vehicle you depend on and spent ton$ on only to consistently and sporadically let you down. Good luck, please keep us informed along the way.
Thanks so much for the detailed and thoughtful reply — really appreciate the time you took to share these insights. Here’s my response:
1. Parking location & timing:
Yes, the car is always parked in the exact same spot in my driveway, facing the same direction. The battery drain only occurs over weekends when the car sits unused for one or two days. During weekdays, I’ve never had any starting issues.
2. Door & trunk activity:
I rarely open the trunk or doors multiple times over the weekend, and usually not without starting the car afterward. I wasn’t aware of the “three openings” note in the manual, but I’ll double-check that.
3. Key fobs & connected services:
Both key fobs are kept inside the house. I would rather keep Connected Services, so I could monitor the battery status using the Genesis owner's app. I did disable the Multimedia and Map update by OTA.
4. Electrical accessories:
No devices (chargers, adapters, etc.) are plugged into any USB or 12V outlets when the car is shut off.
5. Light activity:
No interior or exterior lights were ever on when the engine is off.
6. Battery tender test:
I haven’t used a tender yet, but that’s a least favorable option I would ever want to try out — definitely not ideal for a $80k vehicle.
Again, thank you for all these detailed suggestions. I'm sure it helps others who might be facing the same frustrating battery drain issue.
For reference, this is the drastic battery drain I noticed using the Genesis Owner’s app while the car was parked in my driveway. I used the car on 11/06 and it was parked in the driveway since then.
11/07/2025 at 07:06 AM - Battery at 88%
11/07/2025 at 06:46 PM - Battery at 63%
11/08/2025 at 11:20 AM - Battery at 34%
Yes, that is horrible and not normal. I would send those same screen shots to Genesis Regional and Corp management if you have not already done so, and open a trouble ticket with Connected Services so there is an ongoing correspondence record. If there is a car electrical specialist in your area (or even a very good electrician), I would ask them to take a look at it. Ask around. Definitely something is on that should not be or there is a short in the wiring somewhere. One other temp option I did not mention, though it too is a bit of a pain, is to install a "kill switch" on the battery so the (+) is disconnected each time. Of course you'd have to turn in back on to reconnect and you "might" lose radio settings, etc., each time. At least with a tender those would be stable.
