Riggs223
- Mar 14, 2019
If there is a better spot for this thread could someone please move it
I just bought a 09 genesis sedan it has the nav heated seats ect (not sure if that’s an option or standard is why I stated)
But anyway it has some electrical problems the battery light stays on the whole time I’m driving, it pops up on my screen to have the car running while I’m using multi media when I’m driving down the road had the alternator and battery both tested at advance they said they was good I tested the voltage with my Multimeter and I’m getting 13.5 volts
But the main problem Im having is it started not wanting shift out of park unless I hold down the shift interlock Button and i then noticed my brake and reverse lights were not working so the first thing I did was replace the brake pedal switch hoping that would fix the shifting and brake light problem but it did not
i unhooked the battery and hooked it back up and the shifting problem stopped but then started back a few days later but back to the light problem
I checked the relays and fuses under the hood and according to the chart on the fuse box lid it looks to me like it has 2 relays and 2 fuses if I’m reading it right I’ll post pics but anyway the 2 spots it’s showing those relays to go in do not have contacts for a relay down in the holes so now I’m stumped
