Battery trouble
Kelly Thomas
Hello, I have a 2011 sedan 4.6l that completely drained the battery while on the roadth e engine went into limp mode before I could get into a parking space. After replacing the battery it started started up fine and ran good all the way home. The problem seems to be the alternator not charging. Strange thing is, the seat warmer no longer works. Could there be a fuse blown that would take out the alternator and seat heater?
It may be that the seat heater is disabled when battery voltage is too low. You may only have a charging system problem. That problem is likely the alternator, but there are tests that can be done to make sure it is the alternator and not a wiring issue.
