Battery
leonjay
In my normal maintenance I usually check the levels in the cells in the battery. I have lots of stuff in the trunk making this a real chore. I was going to empty the trunk to look at the battery, but it looked like it was sealed. I haven't had a chance to go to the dealer, soooo is the battery sealed???
I don't know if the battery is sealed or not but if it's a maintenance free battery, it's probably not meant to be opened.
it's an AGM battery, no need for you to check the cells. If you want to check the charge you can do so in the engine compartment at the terminal posts near the passenger compartment.
