PARTSCOMBINED
- Sep 18, 2022
- No Genesis Yet!
Hello G70 users,
Do you need more stopping power? I want you to check our FELLA BIG BRAKE KIT for your G70.
Fella brake rotors go through an extensive manufacturing process; heat-treated up to 800°C (1472°F), to ensure the rotors can take the punishment from performance driving
- To install the 6P Monoblock kit, the wheel size should be more than 19-inch. The wheel size 18-inch or 17-inch has to go with the 4PS Monoblock kit.
- 380mm is fit on 6P Monoblock kit. 350mm or 360mm is fit on 4PS Monoblock kit.
- Customers can choose the rotor patterns (Slotted or Drilled or Slotted and drilled)
- Customers can choose the Caliper colors and logo styles
- With over 20+ years of experience in the aftermarket automotive manufacturing world, the Fella brand was created in 2016 to focus on high-quality brake component development
- This G70 Fella Big Brake Kit kit provides shorter stopping distances, better brake modulation, firmer brake pedal feel, and less brake fade when compared to the factory Brembo Kit
- Fella's Big Brake Kits include a monoblock lightweight 6-piston caliper that is offered in 4 color different options to choose from: RED, BLUE, BLACK, and YELLOW
- Fella Rotors are 2-piece floating rotors that are designed to reduce heat while also reducing weight
- Included with the kit are Fella's high-performance signature sport ceramic brake pads that are a perfect match for the G70
- Fella brake rotors go through an extensive manufacturing process; heat-treated up to 800°C (1472°F) to ensure the rotors can take the punishment from performance driving
- HEL high-quality reinforced brake hoses are included to avoid vapor locking & corrosion
- This kit includes premium Fella Floating Rotors for excellent heat dissipation
- Please allow for 5-7 business days for the kit to be shipped
