Bleed Air from Power Steering Pump
Prey521
Hello,
Recently installed a new PSP in my 2013 Genesis but am still experiencing whining, though a lot less and not as loud as the old one.
I believe that there may still be air trapped in the system. I've read multiple ways of doing it but some of it appears to be conflicting.
Is there a specific way that it should be performed on the Genesis?
Thank you
Here's the manual page (2012 4.6 with the electrohydraulic pump). Don't ask me about how to do step #4 with a push-to-start, I didn't write it. Maybe shut it back off real quick? The key here seems to be the repeated engine-off lock-to-lock iterations to bleed the majority of the from the system before the engine is started up and run for more than a few revolutions. My guess is that running the engine before the majority of air is bled can foam the fluid and cause lingering issues. Which may be your situation.
If your car does NOT have the electric pump, the procedure is:
