Bluelink Widget Remote Start Settings
CSULA21
Los Angeles, CA
Some one please correct if I am wrong, but when using the "Start" fx from the widget, shouldn't the settings (AC/Heater, front defroster, and temperature) be the same as the previous remote start?
Whenever I use the widget to start the car, the temperature is turned all the way up on the defroster; making for a hot interior; IT'S SUMMER! However when I use the app and select the desired settings (in this case, lowest temperature), the car starts fine. From my previous Genesis sedan, whenever I used the Start from the widget, the car would turn on with the previous settings. Am I missing something?
You can set a default preset in the app. Click on "Remote", then "Start" and check the individual setting and make the one you want default.
Will try that; THANKS!
Doesn't work, lately. New phone, reinstalled app, have default profile set. Use widget and profile is not respected - just starts the car with nothing turned on.
2022 G70 - This still doesn't work for me, i.e., default is NOT used when using the Start widget on Android. Any updates?
