Boost Lag
Husky
148
43
I think what some perceive as lag may be the response of the drive by wire electronic throttle. It can be really annoying. It was awful in my 3 series, even in sport mode. Had to buy a $300 Sprint Booster, which helped quite a bit.
NLJ
980
I like the slight lag cause the power comes in all at once after and feels good!
OMG70
Master Bruce!
843
913
93
LA/OC, California
Only noticeable in Comfort and Eco, which I believe intentionally retard the pedal feel a bit so it's not so touchy. In sport, I feel like the pedal feel/responsiveness is perfect
tarhoosier
156
43
Charlotte
On a somewhat related note, I have read that an actual horse produces around 15 horsepower.
From Wikipedia. The peak power over a brief time is ~15 hp. For agricultural work and horse type it is ~1 hp
In 1993, R. D. Stevenson and R. J. Wassersug published correspondence in Nature summarizing measurements and calculations of peak and sustained work rates of a horse.[13] Citing measurements made at the 1926 Iowa State Fair, they reported that the peak power over a few seconds has been measured to be as high as 14.9 hp (11.1 kW)[14] and also observed that for sustained activity, a work rate of about 1 hp (0.75 kW) per horse is consistent with agricultural advice from both the 19th and 20th centuries and also consistent with a work rate of about 4 times the basal rate expended by other vertebrates for sustained activity.[13]
maxsilver
176
43
Imagine still getting the rush of power but with no perceived lag, that feels even better. I've found that is what my BMS Pedal Tuner allows to happen.
sethsquire
271
63
So I guess while a horse has 15 peak horsepower, output at any given time depends on the RPM's of the horse...
Husky
148
43
The only lag I notice sometimes in my 3.3 is the gas pedal, especially if it's right after braking.
Pedal Commander
