Bouncing passenger belt buckle fix
Iggy
Southern NH
A small annoyance of driving with the windows down is that the passenger belt buckle bounces against plastic door pillar cover. I came up with a cheap and easy solution.
Pack of 3 Neodymium disc magnets from home depot
Gorilla tape
soft velcro
Open both passenger side doors and pull the weather strip rubbers out on the pillar side then gently pull the plastic cover from the edges until the top portion is free. I set in the 3 stacked magnets about 6 inches from the top in line with where the belt hangs naturally and secured them with some black Gorilla tape, there's a pocket from the mold process that the magnets set into quite nicely.
I also attached a strip of soft velcro to the top inside of the buckle to prevent marring of the plastic cover
About 5 bucks and 10 minutes of time
Gorilla tape
soft velcro
Thats good stuff man !! Thanks for sharing,. This is probably the first car ever that I never put the windows down.
So car windows still roll down?
5 min fix. Just take the front and rear weatherstripping loose and snap the panel loose at the top and add a very strong magnet. I used 3M double back and that’s it snap panel back on and weatherstrip back on. Done
Thank you both for sharing. This issue has been a small annoyance for me and I have been trying to think of a way to manage it without adding anything noticeable to the interior (like lining the plastic with felt, etc.). Even when the windows are up (which is most of the time) the buckle bounces off the plastic while driving over uneven pavement with nobody in the passenger seat.
thanks for this - Yeah, previous cars I have owned have a receptacle built-into the B-Pillar to mitigate this issue.
This has been driving me crazy!
Just did the install - Perfect - Again, thanks so much for this idea!
