Brake Squeal
nemec4
NY
2013 Genesis v6 with 40K. Replaced rotors with Bosch and brakes with Akebono Ceramic about 5k ago. Brakes now squealing in drive after car sits but goes way after 1st 2 brakes. Any ideas?
I had the same issue on my 2012, make sure that the shims on the pads are tight, use brake grease on the ends on the pads, where the pins go through the pads, and on the pad retainer where it contacts the pads. Do not apply anything between the shims and the pad or the pad and pistons.
