The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
I won't put them on my car because I know people that have had problems with them.I had a tire that developed an air leak. So I brought it to a tire shop. When I came back to pick up my car they told me they couldn't get the tire off because the wheel lock and the key were damaged. Has anyone else had a problem with a broken wheel lock or key?
I'm involved in a dispute regarding the Genesis branded wheel locks that were included with my GV60 purchase. A tire shop managed to remove two of them, but then they were stripped. Long story short, I had to have the car towed nearly 100 miles to the nearest Genesis dealer who had a master set of keys. The security on those bolts is amazing, but not when the key rounds out. Has anyone else dealt with this? Mine had a more or less 4-leaf clover design with rounded petals. The newer models seem more star shaped.I had a tire that developed an air leak. So I brought it to a tire shop. When I came back to pick up my car they told me they couldn't get the tire off because the wheel lock and the key were damaged. Has anyone else had a problem with a broken wheel lock or key?
Are you saying that the key provided with the "locks" did not work correctly? Or, that you were not provided a key?I'm involved in a dispute regarding the Genesis branded wheel locks that were included with my GV60 purchase. A tire shop managed to remove two of them, but then they were stripped. Long story short, I had to have the car towed nearly 100 miles to the nearest Genesis dealer who had a master set of keys. The security on those bolts is amazing, but not when the key rounds out. Has anyone else dealt with this? Mine had a more or less 4-leaf clover design with rounded petals. The newer models seem more star shaped.
The key rounded out and would not move the lug bolts.Are you saying that the key provided with the "locks" did not work correctly? Or, that you were not provided a key?
It sure seems like this should be a simple warranty issue.The key rounded out and would not move the lug bolts.
Tire dealer blames Genesis and vice versa and I'm in the hole for $1,000It sure seems like this should be a simple warranty issue.
Wow, I just rotated my tires and one of my lock studs broke! The 'custom' shape insert came off the top of the wheel stud, it's a pressed spline into the stud body. I was able to get the wheel off but I didn't put that particular lock back on the car. I rotate my tires every 6K miles so they have been on/off a few times as I'm approaching 80K on my car.I'm involved in a dispute regarding the Genesis branded wheel locks that were included with my GV60 purchase. A tire shop managed to remove two of them, but then they were stripped. Long story short, I had to have the car towed nearly 100 miles to the nearest Genesis dealer who had a master set of keys. The security on those bolts is amazing, but not when the key rounds out. Has anyone else dealt with this? Mine had a more or less 4-leaf clover design with rounded petals. The newer models seem more star shaped.
Yikes!Wow, I just rotated my tires and one of my lock studs broke! The 'custom' shape insert came off the top of the wheel stud, it's a pressed spline into the stud body. I was able to get the wheel off but I didn't put that particular lock back on the car. I rotate my tires every 6K miles so they have been on/off a few times as I'm approaching 80K on my car.
Seems easy enough to defeat them. Instead of a tow, they should have asked a local kid to take them off.Tire dealer blames Genesis and vice versa and I'm in the hole for $1,000
The Genesis locks have a slip rings so the socket over approach doesn't work. the stud is deep in a narrow channel stops extraction unless you are willing to damage the wheels. They are awesome locks that the dealer added and ruined us when away from a dealer.Seems easy enough to defeat them. Instead of a tow, they should have asked a local kid to take them off.
How to Remove a Wheel Lock When You've Lost the Key | Capital One Auto Navigator
Tools, techniques, and tips for removing a locked wheel when the key is missing.www.capitalone.com
My conversation with Genesis was pleasant and productive. Genesis was generous with their part of the wheel lock mayhem, and conversations with the tire dealer's loss mitigation folks are under way. I'm optimistic that both the Tire folks and Genesis will fix my financial loss. Thanks, Genesis!I'm involved in a dispute regarding the Genesis branded wheel locks that were included with my GV60 purchase. A tire shop managed to remove two of them, but then they were stripped. Long story short, I had to have the car towed nearly 100 miles to the nearest Genesis dealer who had a master set of keys. The security on those bolts is amazing, but not when the key rounds out. Has anyone else dealt with this? Mine had a more or less 4-leaf clover design with rounded petals. The newer models seem more star shaped.
