Bulbs for high beam/DRL
cruno
13
NJ
Equus (2011-2016)
I have been searching everywhere to find the correct bulbs for my H7 highbeam/DRL lights. In most pictures I see they are a bright white and match the color of the low beam bulbs.
The LED kit I tried does not fit with the bracket that holds in the bulb. The Halogen/Xenon bulbs I tried are even more dim than the low beams (and slightly amber) because there is an opaque coating on top of the bulb, so the beam never goes directly through the projector.
I am specifically looking for the bulbs for the Korean headlights (part #s: Left 92101-3N101 / Right 92102-3N101). NOT the US versions.
I tried contact Hyundai dealerships but they cannot find the Korean part numbers. I tried Sylvania's website by entering the part number but that says it doesn't have that part number in their database.
For reference:
These do not fit - https://www.amazon.com/gp/product/B07FDZD7VZ/ref=ppx_yo_dt_b_search_asin_title
And these are too dim due to the top coating - https://www.amazon.com/gp/product/B000CO7N5Y/ref=ppx_yo_dt_b_search_asin_title
brucehulkbanner
MD
For reference:
When are you using the high beams? Do yours come on as DRL with lower light output along with the halo and led outline?
cruno
13
NJ
Equus (2011-2016)
I use the high beams on dark roads at night when there are no other cars.
When I am not using the high beams or the low beams, the high beam bulb should be outputting a lower power beam for the DRL along with the LED ring and outline strip.
With the halogen bulbs that were too dim to use as a high beam I was able to see that functionality in action.
brucehulkbanner
MD
Ok I understand. I will check with a buddy who swapped out his high beam bulb. I will reply once he gets back to me
Pedal Commander
